kai: I'm I correct in saying with the new active kits if you use the pc input it won't work with the standard 5 pin din to 3.5.
You are! Answered long time ago in the old forum ...
http://archivedarchivedforum2.beoworld.org/forums/t/15997.aspx?PageIndex=1
