Beovision 6 sound problems
TomLyons
Posts 30
TomLyons Posted: Fri, Mar 9 2012 8:43 AM
I wonder if somebody could offer any suggestions to a problem that has just started.
I have a BV6 as a link television to a BV10.  All was working well until I set up the DTV module in the BV10 last night (The analogue signal is now being switched off in my TV region).
The BV6 worked properly last night but when using it this morning the sound volume will not stay where I set it.  The volume goes up when you press the volume control but then goes straight back to 0 and the volume display stays on the screen.
Does anybody have a suggestion for what could be the problem?
Thanks in advance.
Tom
Callen
Posts 1
Callen replied on Fri, Mar 9 2012 4:29 PM
Do you have more than one remote? If so can you try the remote from the main room in the link room. Reason I ask is the volume button on one of my Beo 4's got 'stuck' down, creating the exact same problem you're experiencing.
Regards,
Cal
Page 1 of 1 (2 items) | RSS
