hi all can enyone help i seem to only have sound on one side of my system could this just be a settin issue tryed balance left ok no right sound???? its a beogram full system 4500
Is it only apparent on phono input?? If yes then..........
Could be mute relay or cartridge faulty.
Could be fault in DIN plug but unlikely.
Regards Graham
From personal experience, assuming all connections look ok, the most common cause for a channel to drop out is the cartridge.
Lee
