Beolab 4000 morning 1
This post has 13 Replies | 1 Follower
kai
Posts 362
kai Posted: Thu, Jul 26 2018 12:24 AM
I just bought a pair of used lab 4000 speakers, I have the Sonos amp I know I can use them with the amp but would I be better selling the amp and buying the connect?
marexy
Posts 710
marexy replied on Thu, Jul 26 2018 6:12 AM
Beolab 4000 are active speakers with integrated amp.
All you need is surce, preamp, or like.
Rob - Danish AV
Melbourne
Posts 376
Buying the Connect would be a better option. use RCA out of Connect to RCA in on Beolab 4000.
Speakers will go into standby after a loss of signal after a short while.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi kai,
You can use the Sonos Connect:Amp with the Beolab 4000 speakers, but as mentioned above, the cheaper Sonos Connect is the better option, as Beolab speakers already have amplifiers built in.
Using the Connect:Amp unit also requires a special Attenuated Converter ( https://soundsheavenly.com/line-in-connection/power-amplifier-to-beolab-line-in-attenuated-convertor-kit ) for the Connect:Amp unit, as well as the cable listed below, to reduce the amplified outputs of the Connect:Amp to safe levels for the Beolab speakers to accept.
For either version of Sonos unit, you will then need one set of the following cables for each pair of Beolab 4000 mk.1speakers to be connected:-
https://soundsheavenly.com/line-in-connection/av-processor-pre-amp-sonos-to-beolab-rca-line-in
Please set both speakers to "Line" mode using the small switch at the rear.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
chucky
Posts 331
chucky replied on Fri, Jul 27 2018 8:56 PM
Buy a beosound core??...
kai
Posts 362
kai replied on Fri, Jul 27 2018 11:31 PM
Guys thanks for the advice, I will have a look at the core, not sure if I want pay the money the older kit is just a lot more reliable than current kit
elephant
AU
Posts 8,219
elephant replied on Sat, Jul 28 2018 3:22 AM
Core is quite reliable - just needs the occasional (like yesterday’s) 10 second power recycle.
BeoNut since '75
trackbeo
Posts 644
trackbeo replied on Sat, Jul 28 2018 1:50 PM
That's supposed to be humor, right?
Edit: Try to be helpful...  OK.  @kai, if @elephant wasn't trying to be funny, it's still a joke: No, you should not buy a Core.  No no no no no.  Well, at least not unless you have a B&O multi-room setup going.  Yes, you should swap to a Sonos Connect.  You can tell from your use of their application, how convenient it is.  If money is an issue (e.g. buying used BL4000's), a pre-owned ZonePlayer 80 still works fine with the current software too.  I have never had to "occasionally" re-boot my Sonos system.  (Well, they are a little fascist about forcing updates on you, but otherwise never.)
kai
Posts 362
kai replied on Sat, Jul 28 2018 10:05 PM
Hey trackkbeo, don’t worry I won’t by a core, I will go the Sonos route, will sell the connect amp by a connect and still have money left over
elephant
AU
Posts 8,219
elephant replied on Sun, Jul 29 2018 2:23 AM
It was a perception correction not a recommendation !
BeoNut since '75
David
Oxford
Posts 50
David replied on Sun, Jul 29 2018 8:54 AM
Why not try a Chromecast Audio via the line in.
kai
Posts 362
kai replied on Sun, Jul 29 2018 12:44 PM
That’s another option. Thanks
Rob - Danish AV
Melbourne
Posts 376
A Sonos connect would work better with the Sonos amp? Than a google chrome.
dont try and over complicate the system. A Connect is best, seen it used a few times that way
peria
Posts 321
peria replied on Tue, Jul 31 2018 3:01 AM
I have 3 Sonos Connect to two pairs of 4000’s and one 8000. Works great!
Enjoy.
Page 1 of 1 (14 items) | RSS
