I currently have a pair of Beolab 20 hooked up to a Denon X4300H and was wondering if there is any way to make adjustment to the bass.
Thanks!
Hi lightsyde,
You can either use the "Position" switch on the socket panel of the speakers for a basic bass adjustment ("Free" gives most bass, "Corner" gives the least) or you may find that the "Speakers" section of the Denon menu gives you the best range of bass adjustment.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
BeoNut since '75
And don't forget to calibrate Audyssey to your room...
Thanks everyone for the help and I will definitely try everything suggested!!
Fidse:All that nice music in a playlist and then, booom! A wild Nik & Jay track appears
