Hello,
I've got five Beocom 6000's, two mk2's and the rest mk1's. The other day one of the mk2's froze when it rang.After a while it just said turning off... and stayed like it. I took the battery out for a while to see if it would give it a jog but it just went back to turning off...
Does anyone know how to remedy this? I wondered about a handset reset but I don't know how to do that, or could it be a battery issue or just time for a new handset?
Thank you,
David
If you want to try a reset, have a look here: https://archivedarchivedforum2.beoworld.org/forums/t/3649.aspx
