Hi B&O people, I've just upgraded to a BeoVison 7-40 HDMI from my 7-32 with a SCART cable.I was trying to work my way around the menus when I tripped into a menu that allowed me to adjust a "lip-sync" delay ... so I thought I'd have a twiddle with is as I was wondering if I could use this with a bit of low latency BlueTooth voodoo to drive the speakers wireless.
But after setting up a 250ms lip-sync delay a can longer find the menu !!!Yikes!I'm going to be in trouble when the misses comes home if I cant fix it ...
Anyone know how to find that menu again?
Ah! I have solved the problem now .....
The menu was not on the B&O .... it was on the Humax box.
Problem sorted, cheers.
