How to copy the content of a HDR1 onto my PC?
stephanzenden
Posts 1
stephanzenden Posted: Fri, Aug 3 2018 11:40 AM
I have an old HDR 1 with movies on it. How can I copy these into my PC?
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Aug 3 2018 4:29 PM
Welcome to Beoworld!
The best way may be to remove the HDR1's hard-drive, connect this to a PC using appropriate cables and then extract the files.
Edit:  But according to this thread a PC may not be able to read the files because the disc is formatted in a non-standard way: https://archivedarchivedforum2.beoworld.org/forums/p/11517/86154.aspx
Perhaps you should use something like this, although the quality may not be great: https://www.amazon.co.uk/Video-2-PC-Capture-Windows-Camcorder-transfer/dp/B0049BE3TA/ref=pd_lpo_vtph_tr_t_2?_encoding=UTF8&psc=1&refRID=4GVD838601CCAKFMX9E4
Page 1 of 1 (2 items) | RSS
