Sign up for AirPlay2 beta testing
This post has 96 Replies | 3 Followers
elephant
AU
Posts 8,219
elephant replied on Mon, Aug 13 2018 11:59 AM
madskp:
mbee:
Ok, no integration more than BLC.
What I can't do (and I've double-checked that everything is good on the ATV settings) is wake up my BV8 with the ATV/ATV Remote/Airplay. Completely impossible. I can control the BV8 volume with the ATV remote but that's all.
diisign.com
Madskp:
Is the TV Source in use on your BV8? TV is the only B&O IR command the Apple remote sends appart from volume. So for this to work optimal you have to select TV as the source button for the HDMI port the Apple TV is connected to.
I moved my ATV from DVD to TV and disabled all aerial inputs. Purely coincidentally in the past week, however this probably contributed to my solution.
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Mon, Aug 13 2018 12:02 PM
Hiort:
It seems that Sonos users experience similar problems:
https://en.community.sonos.com/troubleshooting-228999/trouble-adding-play-ones-to-home-app-ios-6809384
So the thread poses two solutions both that worked for multiple people:
1/ check you are adding via a user whose iCloud account was the original one to set your HomeKit environment up,
2/ AND/OR
brisgasdoc
brisgasdoc 1 month ago
plancky wrote:
I have tried power down both phone and Sonos One. Still no joy. The Sonos One never appears as a device when i try to add it within the HomeKit add accessories section ...
All this only worked after I updated to iOS 11.4.1
BeoNut since '75
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Aug 13 2018 12:11 PM
elephant:
Hiort:
2/ AND/OR
brisgasdoc
I checked and its the same icloud account everywhere.
I´m on iOS 11.4.1
elephant
AU
Posts 8,219
elephant replied on Mon, Aug 13 2018 12:19 PM
Hiort:
IΒ΄m on iOS 11.4.1
Sounds like try step 2 ... not a reboot but a power off and on of the iPhone
I had problems in part because of my Bermuda Triangle of TimeCapsule WAPs, so I need to make sure was connected to the right speed network, and also ideally the same node for the setup process.
Once setup I could live with the β€œconnecting ...” pauses come timeouts
BeoNut since '75
CB
> You are Here <
Posts 1,762
CB replied on Mon, Aug 13 2018 1:00 PM
elephant:
Armageddon, Bermuda Triangle...
Scary place you live in Laughing
elephant
AU
Posts 8,219
elephant replied on Tue, Aug 14 2018 1:10 PM
CB:
You have no idea how scary ...
πŸ‘ŠπŸ™€πŸ€–β˜ οΈπŸ‘½πŸ€–πŸ§Ÿβ€β™€οΈπŸ€‘πŸ§›β€β™€οΈπŸ‘©β€πŸŽ€πŸπŸ¦–πŸ¦‘πŸŠπŸ²
BeoNut since '75
CB
> You are Here <
Posts 1,762
CB replied on Tue, Aug 14 2018 5:31 PM
LaughingLaughingLaughing
madskp
Denmark
Posts 321
madskp replied on Fri, Aug 17 2018 5:24 PM
I have made a new thread regarding the IR control functions of the Apple TV and Beovisions and also mentioned the Airplay functionality and quirks. https://archivedforum2.beoworld.org/forums/p/34673/256188.aspx#256188
elephant
AU
Posts 8,219
elephant replied on Fri, Aug 17 2018 10:52 PM
madskp:
It’s a great tutorial β€” thank you for taking the time to put it together
BeoNut since '75
na3345
Posts 2
na3345 replied on Thu, Oct 18 2018 12:48 AM
Any idea when the Airplay 2 update will be out? My B&O dealer mentioned that it was supposed to be out in August/September but I havent seen anything yet.
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Oct 18 2018 9:51 AM
Devices on the Beta track received a new update of firmware the other day.
Performance have improved a lot, but I still see problems with sound out of sync.
So, they appear to have some work to do still.
/C
elephant
AU
Posts 8,219
elephant replied on Thu, Oct 18 2018 11:47 AM
Hiort:
/C
I got those updates too (Essence & Core).
I have not noticed any change: neither +ive nor -ive.
BeoNut since '75
Millemissen
Flensborg, Denmark
Posts 14,680
Are the problem between ATV’s on a BeoVision and the pure audio devices (AP2 compatible)?
elephant
AU
Posts 8,219
elephant replied on Fri, Oct 19 2018 2:46 AM
Millemissen:
MM - I would be happy to answer the question if I had some context ... were you asking me ? What statement(s) prompted the question ?
And do you include Eclipse & Core as pure audio ?
BeoNut since '75
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Oct 19 2018 6:38 AM
Millemissen:
The problems I see is that devices are (sometimes) slightly out of sync.
Earlier issues I experienced, like shaky volume control and devices not playing after being selected, appear to be fixed.
Millemissen
Flensborg, Denmark
Posts 14,680
Just don’t think that B&O is the only one with this kind of problems:
https://discussions.apple.com/thread/8408186
Millemissen
Flensborg, Denmark
Posts 14,680
Latest news seem to be:
De reviderede planer for udrulningen af Airplay 2 til Bang & Olufsen produkter er:
Fra november: Beoplay M3, Beosound Core, Beosound Shape (via Beosound Core), Beosound 1, Beosound 2 og Beoplay M5.
*** december: Beoplay A9, Beoplay A6, Beosound Essence (2nd gen), Beosound 35 og Beovision Eclipse (audio only).
Derudover vil den nye Beosound Edge være født med Airplay 2 når den kommer til salg fra midt november.
Source: https://www.recordere.dk/2018/10/bo-her-er-status-paa-airplay-2/
Page 3 of 3 (97 items) < Previous 1 2 3 | RSS
