Calm Radio on B&O
This post has 10 Replies | 0 Followers
AnalogPlanet
Vienna, Austria
Posts 678
AnalogPlanet Posted: Wed, Aug 8 2018 8:24 AM
I very much like the choice of Calm Radio, really a unique set of stations to provide a bit of auditive harmony and serenity into your home.
Sadly, TuneIn stopped supporting adding of custom station URLs so B&O products are locked out of it. It did affect other vendors too, but now I see that practically all - apart from B&O - have developed their own solution. Denon has it, Naim has it, Yamaha, Bluesound, Cambridge Audio too... as well as the Playstation. Needless to say, Sonos is supporting it too.
That leaves B&O as the only vendor with no solution. Such a pitty. Did any forum member found a workaround in the meantime perhaps? I am doomed now with a free version that is interrupting the stream frequently to advertise subscription... ...which I would gladly pay for if B&O wouldn't be the only AV vendor with no solution for their customers.
CB
> You are Here <
Posts 1,762
CB replied on Wed, Aug 8 2018 9:14 AM
AnalogPlanet:
Confused
Since when?
I’m not at home now, so I can’t check for mines, but if confirmed, that’s a bad new...
Do you mean you can’t add any new custom radio AND also the already registered don’t work anymore?
AnalogPlanet
Vienna, Austria
Posts 678
This is where I read it, not sure if it misguiding perhaps: https://calmradio.com/en/internetradio/1798-bangolufsen
Millemissen
Flensborg, Denmark
Posts 14,680
Not sure what you mean?
I did a search in TuneIN and there are several Calm Radio stations available.
Making one or more of these favourites there should allow listening on my Essence.
Which B&O (device) do you have in mind?
Millemissen
Flensborg, Denmark
Posts 14,680
One of the Calm Radio stations in the Bang & Olufsen app - and in TuneIN
Click the pic!
AnalogPlanet
Vienna, Austria
Posts 678
Millemissen:
This is a free stream, and I'm playing it too.
What is not available is the premium, paid stream without interruptions for advertisments and in higher bitrate at 320kbps. So if I subscribe to Calm Radio I cannot listen to the premium stream on B&O devices because of the TuneIn lockout and unlike with other brands B&O does not provide an alternative. Broken Heart
CB
> You are Here <
Posts 1,762
CB replied on Wed, Aug 8 2018 12:54 PM
Millemissen:
It’s about custom URL, not the radios listed by TuneIn.
Note that to add a custom URL you need to use the TuneIn app
https://help.tunein.com/what-is-a-custom-url-and-where-can-i-add-it-HkOxgcC9OwM
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Aug 8 2018 4:08 PM
CB:
Note that it’s not possible to add a custom URL on all the OS
So if one would add a custom url as per the instructions in your link, it would not appear under favorites in e.g B&O app?
CB
> You are Here <
Posts 1,762
CB replied on Wed, Aug 8 2018 4:14 PM
I did add custom URLs and they are (were ?) accessible in the B&O app.
That’s why I’m worrying... (I can’t check now)
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Aug 8 2018 6:17 PM
CB:
I tried to add a custom link I found on the internet. It did appear in the app after a while but it did not play on my BeoSound 1.
CB
> You are Here <
Posts 1,762
CB replied on Wed, Aug 15 2018 12:34 PM
Here is a screen copy of the TuneIn app on iOS
The last two radio have custom URLs
Try this one (HD): http://media.radiojackie.com:5873
Page 1 of 1 (11 items) | RSS
