Beogram 8002 motor issue
leosgonewild
Helsinki, Finland
Posts 2,373
leosgonewild Posted: Tue, Aug 14 2018 6:56 PM
How can I fix this issue?
https://youtu.be/R9hbPttO4JU
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Aug 14 2018 8:57 PM
Replace capacitors
Repair cracked solder joints
Replace CPU socket
Repair front panel << / >> opto circuit.
Dillen
Posts 13,191
Dillen replied on Wed, Aug 15 2018 6:59 AM
I can't see the black subplatter in the video.
Perhaps it's just out of view.
NEVER run the Beogram without it.
leosgonewild
Helsinki, Finland
Posts 2,373
Do you mean the bottom plate of the whole unit? I connected the ground to it, but it is lying next to it.
Or do you mean the black plate that is under the vinyl plate?
Dillen
Posts 13,191
Dillen replied on Wed, Aug 15 2018 4:11 PM
The Beogram bottom plate is not important.
The black subplatter (the round rotating part of the eddy-current motor) sits under the platter (the round thing with the radial streaks on it, that carries the record).
Without the subplatter nothing will run and the tacho-opto gets no feedback. This causes the electronics
to send max output to the motor coils (to no avail besides heavy humming) until the drivers burn.
Page 1 of 1 (5 items) | RSS
