Beomaster 1700
AndrewMason900
Posts 3
AndrewMason900 Posted: Sun, Aug 19 2018 11:08 PM
After 15 years I have at last managed to obtain the parts necessary to repair my beloved Beomaster 1700.  Unfortunately, in the interim I have collected a number of CDs, which cannot be played on my Beograd Cassette player.  Is it possible to plug a B & O CD player into my 1700, and if so is there a particular model I should look for?
lawrencejmcook
Posts 742
Hi Andrew,
I don’t know what connectors you have on the BM1700, but if you have a Tape 2 input, this should do. A physical adaptor may be required with some of the below CD players.
Given that the BM1700 has no datalink or remote control, you’re better of with a Beogram CD that has its own controls:
- Beogram CDX or CDX2
- Beogram CD3300
- Beogram CD 3500 or 4500, but these have less informative displays and offer less sophisticated control than the above.
- Beogram CD50 if you can find it with its own dedicated infra-red remote.
Happy hunting,
Lawrence
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Aug 20 2018 8:49 AM
There are two Beomaster 1700s though I am sure you mean the later one with the tractor bands as the other is a tuner. I would get a Beogram CDX - it is an interesting machine in that it is a 14 bit oversampling unit but it sounds wonderful - warmer than some of the machines that came after and is not remote control. It will need an adapter as it has a fixed lead with phono plugs but you could get the connector, originally made for the 1900/2400 which plugs into the tape input and allows you to attach both the CD player and tape player and choose which you want to listen to via a switch on the connector.
Edit : I found the product page!
Peter
Page 1 of 1 (3 items) | RSS
