steve1977:but realized you cannot connect a BL11 to a BV unless you have a stereo pair connected as well.
kallasr:Are you sure? Never heard about this. Ralf Living Room: Beosystem 4, Beolab 7-6 (Center), Beolab 8000 (Fronts and Rears) and Beolab 2. Screen: Panasonic TX-P65STW60 Home Cinema: Beosystem 4, Beolab 7-2 (Center), Beolab Penta 2 (Fronts), Beolab 4000 (Rears) and Beolab 2. Projector: Sony VPL-HW55 Home Office: Beosound 9000 MK3 on horizontal wall bracket with Beolab 5000 Speakers Bedroom: Loewe TV with Beolab 6002 and Beolab 11 (all White) In storage: Beolab 5000/Beomaster 5000 (1960s).
I dug out the old forum post. Ravsted wrote: "in a none standard setup like this I cannot recommend connecting a B&O sub". Anyone with experience whether it is indeed possible to connect a BL11 (only) to a BV5?
https://archivedforum2.beoworld.org/forums/p/23016/190402.aspx
Yes, you can connect just the subwoofer to the TV, I think the suggestion was that this may not give you much improvement. Beolab 11 is best as a music speaker, for use with smaller satellite speakers, rather than a subwoofer for movies.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Thanks, this sounds good. Could I connect it via Powerlink? The earlier posts in above link say that "front speakers has to be selected (Beolab Penta for example) if not, the subwoofer socket won't be enabled.". Given I don't have front speakers, this would not work for me.
From memory, I think this varies depending on the software level of the TV. The best option is to try connecting the subwoofer via Powerlink and see if the TV will accept this without front speakers connected. I would advise against using the front Powerlink socket for the subwoofer (use the Subwoofer socket) so that you get the correct sound from the TVs internal speakers.
