Eclipse 65V1-32Beosound M5Essence MK2BLI
Seanie_230:Hello all I have a weird problem with my avant 55 which is intermittent. I have the STB brackets on the back holding a PS4 and SkyQ box. When I turn the TV it always swings out into position but 80% of the time when I turn him off is turns on the pole but does not go away. Pressing the stand button works most of the time. Any ideas ? Any sensors that might be a problem or an error log to look at? Cheers Sean BLGW - Rekindling the love of ML
How about on the BeoTool app you can download, and then there is an option to "generate a service report"
So i tried that, and it doesn't give you any logs
But under reports you can fill in some details and you can "start log submission"
but i think a reset of the stand by position.
Also what about the cable that connects to the stand? Maybe that's gone, can you try a new one? You can lift up the silver base
Let me know how you go
