I've read a couple of threads about replacing the old light bulbs in the beomaster. It seems that the service manual is incorrect and that the bulbs should not be the specified 12v 1w, but rather 15v 1w. Is this true?
I can't find a 15v bulb the closest I can get is a 14v 80mA bulb. Would they fit?
This is the one I have been looking at :
https://dk.rs-online.com/web/p/signallamper-med-gloedepaere/6559356/
I do have a spare unit I could steal some bulbs from if that's a better option, but they are old..
I can supply lamp kits containing correct lamps.PM or email me.
Dillen: I can supply lamp kits containing correct lamps.PM or email me. Martin
Recommended
Thanks, but it didn't really answer my question...
None of the specs you mention are correct.
The kit is same price - if not a bit cheaper - than the lamps you link to,- which are also far too big to fit in the lamp holders.
