Fitting a third pair of speakers to 9500, how, where?
veritas71
Posts 3
veritas71 Posted: Fri, Sep 7 2018 6:24 PM
Hello all.
First of all, apologies as I know little of the 9500 apart from always wanting one, which I now have.
Mine has been purchased with a pair of RL60, a pair of CX100 and a pair of CX50.
It also has the MCL 2047 thingy and 2 sensors for other rooms? Which looks complicated.
As I want all 6 of my speakers in the same room, how would I wire them to the 9500?
Can I just plug the CX50s into the power-link socket (whatever that means).
I don't want to use the MCL if possible as too many wires.
Thanks in advance.
Lee.
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Sep 7 2018 6:52 PM
Just download the Manual on the B&O website… and you will find out how to attach (at least 2 of) the speakers. A second pair might work with the MCL sockets.
https://www.bang-olufsen.com/~/mediaV3/Files/user-guides/singles/BeoCenter9500_UK.pdf
Ralf
leosgonewild
Helsinki, Finland
Posts 2,373
Why do you want to run them all at once?
Have you checked the foam surrounds on the speakers? They are probably rotten. First thing is to have them refoamed.
veritas71
Posts 3
I have a large room where 6 speakers would work.
Their condition seems as new, vacuum packed since 2002!
veritas71
Posts 3
Thanks,
I have all the documents, I was just wondering if there is a plug for a third set.
Page 1 of 1 (5 items) | RSS
