Hello,
does anyone have expierence with the DAB Radio of OneRemote.dk? Want to connect this radio to a Beolink active. Can you really control this radio with the Beo 4 remote on the ML bus?
https://shop.oneremote.dk/en/product/oneremote-dabwifi4/
I had the internet radio version with DAB and FM - it was very good and can be connected to a beolink converter and act as an Audio Master - or spare video socket on the TV - if you take a look at the site and download the user manual it will give you all the info you need. It's quite a versatile device - mine developed a fault after 3 years but I don't think that's common. The company is also very helpful.
Likewise. I have used a OneRemote DAB/Wifi/FM version for several years with no problems. It was connected to my BC9500 and I used to control it with Beo4 (even from other rooms via MCL!).
