I have updated the UK Freview TV Logo pack I made a couple of years ago; Each logo is named by Channel Number then Name. ( I have not done the radio channels)
When using the cofig tool you can replace the channel logos that are in there and have a uniform button look. They will fit on a 3 row X 3 column page.
I have tried to attach the Zip File but if it hasn't worked please message me.
Enjoy Stoobie
In the Zip file I have also put logos for some of the components I use. I would be happy to try to make buttons for others if you email me a good quality jpeg or bmp.
You have created a really good logo set.. Very nice indeed.
Regards Keith....
Thank you Keith. I have recently updated most of the channel logos as quite a few have changed. I'll upload them in the next few days.
I have updated the logos (Mainly Channel 4 stations). Hopefully the link works
