Creating a Beovox 7.4
This post has 12 Replies | 3 Followers
leosgonewild
Helsinki, Finland
Posts 2,373
leosgonewild Posted: Sun, Sep 9 2018 7:32 PM
Would it be possible to remove the icepower amplifier from a Beolab 7.4, making it a passive speaker?
The reason is that I would like to run it of a standard 5.1 surround amplifier. That way there would not be any need for an expensive amplifier with preamp outputs.
lawrencejmcook
Posts 742
Even if you separate the internal power amplifiers, I wonder how much of the low-level processing is eq.
Similarly, I’ve always wondered what BL8000s would sound like without eq Big Smile
leosgonewild
Helsinki, Finland
Posts 2,373
From the service manual it looks like the sound processing is done before the amps.
lawrencejmcook
Posts 742
Right, so how do you think you could mimic it? Is your AV receiver that sophisticated?
leosgonewild
Helsinki, Finland
Posts 2,373
Don’t have a receiver.
Just researching possibilities. Smile
leosgonewild
Helsinki, Finland
Posts 2,373
Would this unit from Steve solve the problem? https://soundsheavenly.com/line-in-connection/33-power-amplifier-to-beolab-line-in-attenuated-convertor-kit.html
Millemissen
Flensborg, Denmark
Posts 14,680
That is what usually is recommended in such cases.
TWG
Posts 1,672
TWG replied on Mon, Sep 10 2018 7:44 AM
Of course you could rip out all the electronics.
You'll just need to know the crossover frequencies of the speaker chassis inside the Beolab 7.4 and a passive frequency crossover with matching frequencies that you can install in the 7.4 housing. Than you can use it with every external amplifier.
I guess it will be very interesting to listen for the differences of the passive version and the B&O active version.
leosgonewild
Helsinki, Finland
Posts 2,373
How would one duplicate a crossover?
tph
Denmark
Posts 161
tph replied on Mon, Sep 10 2018 9:13 AM
leogoeswild:
I recommend this too. That way you can fully preserve the original sound. Plus, as the loudspeaker relies on ABL for low-end extension, you would lose a significant amount of bass in an active to passive conversion.
— Tuomas | Bang & Olufsen | Bang & Olufsen Create
TWG
Posts 1,672
TWG replied on Mon, Sep 10 2018 11:14 AM
leogoeswild:
- You can search if a crossover with the required crossover frequencies is available as a ready built component
- you can build one yourself or let somebody build one for you.
If you use a separate amplifier for your passive speakers you can also have a look at the professional speaker management speakers, starting with a cheap one like the Behringer DCX2496. There you can adjust everything you like with many many parameters.
https://media.music-group.com/media/PLM/data/docs/P0B6H/BEHRINGER_DCX2496%20P0036_Product%20Information%20Document.pdf
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Leo,
If your receiver doesn't have pre-out sockets fitted, then there is no need to remove the amplifiers from the Beolab 7-4 speaker.  Instead, please use this attenuator on the speaker terminals of the receiver to safely reduce the output levels (this effectively adds external pre-out sockets to any receiver):-
As the Beolab 7-4 speaker doesn't have a Line input option, it also needs a powered cable to generate the trigger signals that would normally be sent from a B&O television:-
https://soundsheavenly.com/line-in-connection/singletwin-rca-to-beolab-2-7-10-2500-powered-trigger-kit
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Peter Pan
Posts 2,088
Peter Pan replied on Thu, Sep 13 2018 10:41 AM
And Beolab 7-4 speaker.
Page 1 of 1 (13 items) | RSS
