Chromecast Audio with Beolabs 8000: volume too loud
jans
Belgium
Posts 394
jans Posted: Wed, Sep 12 2018 7:59 PM
Over the weekend I played around and connected a Chromecast Audio to the line-in of BeoLab 8000’s. It works fine, but I have one question.
When chromecasting from Deezer the volume is very loud. I can only set it to one or two ‘ticks’ when using my iPad volume controls. Streaming from Tune-in or Spotify is bit less loud.
Is there a way to lower the volume so that I can better set the volume level?
leosgonewild
Helsinki, Finland
Posts 2,373
Adjust it in the google home app.
jans
Belgium
Posts 394
jans replied on Wed, Sep 12 2018 8:25 PM
leosgonewild:
Hello Leosgonewild,
Thank you for your feedback.
When looking into the Google Home app on an iDevice, I can select the Chromecast Audio. In the settings section I can adjust bass and treble, and select Dynamic Range on/off, but I don’t see any volume settings. Am I looking at the wrong place?
leosgonewild
Helsinki, Finland
Posts 2,373
jans
Belgium
Posts 394
jans replied on Wed, Sep 12 2018 9:03 PM
Txs I found it. However, i can only go up to 10% and then it is already too loud. Sad
Isn’tthere a way to set the max volume?
leosgonewild
Helsinki, Finland
Posts 2,373
Try turning of HDR. Or get one of these https://www.amazon.com/dp/B004P5MWFC/ref=cm_sw_su_dp
jans
Belgium
Posts 394
jans replied on Sun, Sep 16 2018 12:53 PM
leosgonewild:
I changed the setup. I connected the BL’s to an old iPhone that I wasn’t
using anymore. In the iPhone you can set the maximum volume. Works perfectly!
Page 1 of 1 (7 items) | RSS
