Beocenter 2 timer
frog
Camberley UK
Posts 624
frog Posted: Fri, Mar 9 2012 1:21 PM
Hi, My Beocentre is linked into my Beosystem 3 and I put timers on the Beosystem 3 to switch the radio on and off each morning. Trouble is, the Beocentre 2 now switches on (in addition to the time set on the Beosystem 3) one time. This has just started happening, and I have no idea why or how this timer was set - I just put it down to the Beoghost. There is an active timer set in the Beosystem 2, but I can't cancel it. By switching the timer to OFF, the Beocentre says that it has stored the new setting, but when returning to the timer menu, it says it is still on. Any ideas on how I can cancel the timer on the Beocentre 2?
Peter
Earsdon
Posts 11,991
Peter replied on Fri, Mar 9 2012 3:15 PM
I wonder if the options have been inadvertently reset? The BC2 should by default not use its timer when the BS3 is attached. The BC2 should be option 0 in most set ups as the speakers are no doubt attached to the BS3.
Peter
frog
Camberley UK
Posts 624
frog replied on Fri, Mar 9 2012 7:03 PM
That's it! Thanks.
Page 1 of 1 (3 items) | RSS
