Beolab 3 + Beolab 19 sub
StKong
Copenhagen
Posts 320
StKong Posted: Mon, Sep 17 2018 4:16 AM
Hello gentle folk,
In a conventional setup – either a legacy product or BS Core as a sound source – how do I pair a set of Beolab 3's with the Beolab 19? Any experience with this? The BL19 has no powerlink out which makes me wonder If this is even a viable match. Normally the speakers would be daisy chained to the subwoofer for bass management.
Interested in your experience and thought!
StKong
Aussie Michael
Melbourne, AU
Posts 3,730
The BL19 has a power link it’s just a different connector type.
You set it to wired.
The below manual shows you can daisy chain
https://www.bang-olufsen.com/~/mediaV3/Files/user-guides/beolab-19/3511230_1310_BeoLab19_web.pdf
Millemissen
Flensborg, Denmark
Posts 14,680
Hi StKong
With the BL19 your only option is to use the ‘knobs’ on the sub to just it - or rather to adjust the cooperation with the 3 in your room.
See the user guide for howto.
You’ll have to use yor ears and/or do some measurements at the listening position.
Kind of fiddly - but you’ll get a good result surely.......with a little efford (best done with the help of a friend adjusting while you are listening).
And yes, both speakers must be connected parallel to the source device (the 3’s then daisychained from one to the other or with a pl y-splitter).
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi StKong,
Yes, as Aussie Michael and MM have mentioned, this will work well.  If you need any help working out the best way to connect everything, please let us know the layout of your room and which way is easiest to run the wires (eg. Core -> Beolab 19 -> Beolab 3-> Beolab 3 for example) and we can help you to get everything working.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (4 items) | RSS
