Coding Timer on BM5500 to connect via ML to BL3500
Thomas
Denmark
Posts 6
Thomas Posted: Wed, Sep 19 2018 1:05 PM
Can anyone please assist in how I can code my "timer" on  the BL3500 which is connected via ML to BM5500.
Problem is not to code the timer on BL3500 via Beo4 but how do I get the "time code" in to BM5500?
Can a Beolink1000 be used, and how ?  Smile
( BTW, I cannot make BL control and shift the BM either Indifferent
lawrencejmcook
Posts 742
Thomas:
Can anyone please assist in how I can code my "timer" on the BL3500 which is connected via ML to BM5500. Problem is not to code the timer on BL3500 via Beo4 but how do I get the "time code" in to BM5500? Can a Beolink1000 be used, and how ? ( BTW, I cannot make BL control and shift the BM either
Hi Thomas,
To program your BM5500 to play a source at a certain time I believe you need to use the Master Control Panel 5500. A Beolink 5000 or 7000 may work, as may a Master Control Panel 6500, but I’m not sure. They are all 2-way IR remotes.
Lawrence
Soren
Denmark
Posts 115
Soren replied on Thu, Sep 20 2018 8:51 AM
Hi Thomas
You need a MCP 5500 or 6500 to make timer programming, Beolink 5000 and7000 would not work.
Søren
Thomas
Denmark
Posts 6
Thomas replied on Thu, Sep 20 2018 3:04 PM
Hello Søren
Thx for the fast reply, do you know if it is possible to use a MCP5000 ?
I have this one, but not a 5500
Thomas
Denmark
Posts 6
Thomas replied on Thu, Sep 20 2018 3:05 PM
Thx Alex
Do you think the Beolink 5000 would work? And how to control it, then? (Programming the BM5500)
Soren
Denmark
Posts 115
Soren replied on Thu, Sep 20 2018 3:22 PM
Beolink 5000 wouldn’t work, many years ago it was possible to buy a new PCB for the BM5500 making it work like a BM6500 , but that PCB hasn’t been available for at least 20years. The part number was 8001407.
when that said I am not  sure it’s possible to bring a timer Programming from BM5500 to Masterlink, maybe you need a Videomaster to do the programming, I been the owner of A Beomaster 7000 for 25years and I only tried to do a timer programming 3-4times so my experience is not that big🙁
Soren
Denmark
Posts 115
Soren replied on Thu, Sep 20 2018 3:26 PM
MCP5000 would not work at all, totally different codes, BM 5000 also don’t work with Beolink 1000/Beo4
Thomas
Denmark
Posts 6
Thomas replied on Thu, Sep 20 2018 3:52 PM
HHello again
Well, I'm about to toss the line on the BM and buy a small BS2300 to gain access to ML output direct.
Then I should be able to use the Beo4 to program and operate both BS and BL right? 😊
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Sep 20 2018 4:39 PM
If you mean the Beocenter 2300 then that does not have masterlink. You'd need a Beosound 3000.
(You could of course purchase a Beotime and control the BL3500 from that)
Page 1 of 1 (9 items) | RSS
