Glueing Beogram TX metal arm cover and metal cover plate surrounding the turntable.
zapdady
La Crescenta
Posts 26
zapdady Posted: Sat, Sep 22 2018 10:28 PM
What is the best product to use glueing these cover plates back on? Also, what is your advice on cleaning and prepping both surfaces before applying glue. As always thanks for your help.
zapdady
Saint Beogrowler
Saint Paul
Posts 780
I use a 3M automotive foam tape.
zapdady
La Crescenta
Posts 26
zapdady replied on Sun, Sep 23 2018 3:23 PM
Any advice on removing the old hardened tape adhesive? Thanks.
zapdady
Saint Beogrowler
Saint Paul
Posts 780
I run the aluminum top under hot water and rub off the gunk with my fingers. The plastic I use hot water on a rag to rub the gunk away. Goo gone works too but I prefer the water method.
zapdady
La Crescenta
Posts 26
zapdady replied on Mon, Sep 24 2018 2:21 AM
Thanks, Saint,
I see now that it is easier than I thought. You guys rock.
zapdady
Page 1 of 1 (5 items) | RSS
