Dear all,
Any suggestion for the product to clean the beovision 7-55 TV screen (I think BV11-55 can use the same product)? It will be great the product link is provided!
Thanks!
Daniel
danielshen:Dear all, Any suggestion for the product to clean the beovision 7-55 TV screen (I think BV11-55 can use the same product)? It will be great the product link is provided! Thanks! Daniel
I use a non-abrasive eyeglass or computer screen spray solution for heavily smeared areas, then lightly wipe with a clean microfiber cloth. Use your own breath to touch up streaks and continue light wiping. It takes forever, but it's the only effective way I've found to clean a 7-55 or BeoSound 5 screen.
BeoLab 5, BeoVision 7-55 MK2, BeoSound 5 Encore, BeoSound 9000, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, BeoLab 7-6, BeoSound 8, BeoTime (analog clock), Beo 4 remote.
I always use 2 clean soft dishcloths and hot water. Soak the first dishcloth in hot water and wring it out before using it. Clean the screen with this cloth, and afterwards dry the screen with the other dry soft dishcloth. Never use papier towels, because that van damage the anti reflex coating on your screen.
