Hello!
I must first acknowledge my lack of experience in the electronics realm.
I was recently gifted a pair of BeoLab 3 speakers. I am looking for a receiver to connect them to both my turntable and television. Are there specifications I should be looking for? Or perhaps a better way to go about it? My turntable does have a built-in preamp, and the cables I have for the speakers are 9pin-DIN/Powerlink to RCA.
Thanks so much,
Simon
Beolab 3 can be set up to either receive a line in signal from e.g a receiver (where you adjust the volume on the receiver), or a signal from e.g a Beocenter where you utilize the amplifier that is built into the Beolab 3..
Look here for the setup: https://www.bang-olufsen.com/.../BeoLab-3/EN_BeoLab_3.pdf
Steve and Sounds Heavenly (advertizing on this page) can guide you to the cables you need.
To connect to a TV its the same as above. There you need to feed the Beloab 3s from a volume regulated line out socket on the TV (like headphone jack) and have the Beolab 3s set to "Line".
/C
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
