I would like to know BV 7 SD card slot support which movie formats.
Unfortunately the BV7 does not have a SD card reader. So I guess the answer to your question is "no movie formats"
BeoNet84: Hi, Unfortunately the BV7 does not have a SD card reader. So I guess the answer to your question is "no movie formats"
correct - the USB slot is for software updates
BeoNut since '75
