Hello,
I've bought a Beoplay H6 headset last year and tried to plug it in my ps4 controller some time ago. Sound reception is fine and the headset is recognized by the controller but I can't seem to activate the vocal recognition in party mode : i can hear other people in the chat but none of them seem to be able to hear me,and mic's parameters on the console do nothing.
I've already checked several times the console parameters and everything seems fine. It should be working as the headset's mic works perfectly when i use it on phone calls.
Is there a problem of compatibility between sony's ps4 system and this particular headset ?
Thanks in advance for any answer you may have !
Sorry if this question was already asked.
leosgonewild:The cable is iOS. You need a third party cable.
Thank you ! I'll try another cable then
