Connect Beosound Essence to Beolink Passive
This post has 7 Replies | 3 Followers
ibg001
Posts 80
ibg001 Posted: Tue, Oct 2 2018 2:42 PM
Over time many people have asked if you can connect a Beosound Essence to a Beolink Passive or a ML/MLC converter/amplifier via Powerlink to drive passive speakers.
Yes you can, but require a small change of the powerlink connector on the amplifier. Pin 1 and 4 must be connenced and also connected to ground with a 15k resistor.
Stan
Chicago-area USA
Posts 869
Stan replied on Tue, Oct 2 2018 2:50 PM
Interesting.  I've been doing this for a couple years (Essence connected to Passive) without any modifications.  You *do* need the correct PowerLink cable, and IIRC, there some confusion at my dealer about which cable was appropriate because the first one they sold me did not work.  I think I posted about it here so if someone wants the details, they should search (or just contact Steve at Sounds Heavenly - he always has the correct cable).
Stan
ibg001
Posts 80
ibg001 replied on Tue, Oct 2 2018 2:54 PM
I got the solution from a professional technician that modified many Beolink Passive units this way.
jans
Belgium
Posts 394
jans replied on Tue, Oct 2 2018 5:09 PM
I have the same experience as Stan. The dealer provided me with the right ‘special cable’. Works like a charm!
ibg001
Posts 80
ibg001 replied on Tue, Oct 2 2018 5:52 PM
Do the Beolink Passive then power up and down correctly? Beolink Passive has power up on pin 1.  Newer products has power up on pin 4.
Stan
Chicago-area USA
Posts 869
Stan replied on Tue, Oct 2 2018 6:53 PM
Yes, the passive turns on when I turn on the essence, and goes to standby when I turn it off.
Millemissen
Flensborg, Denmark
Posts 14,680
Should be available at any B&O dealer
The cable workshop, Leics, UK
Posts 2,165
I also have these cables ready made here in case you don't wish to make your own:-
https://soundsheavenly.com/playmaker-and-essence-wireless-streaming/72-388-playmaker-rj45-to-beolink-passive-ml-mcl-converter-mcl2p.html#/9-length-18m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (8 items) | RSS
