i bought a beocord 4500 .The first tape i used was extremly and amazing good sound.I put on a second tape and the sound was very poor and not clear anymore.I did put the first tape back in and the sound was also not good anymore.Sounds like a phoneplayer without RIAA.There is a red triangle on the leftside off the bord that is also lightup when i startup the player.Anyone on here that know what there is possible wrong?
This beocord is used on my beomaster 4500 that is perfektly working.
Clean the tapeheads, capstans and pressure-rollers.The little red triangle is 0dB point (the indicating point between the green and red VU-LEDs).
what will be the best product to clean these?
Tapehead cleaner = Isopropanol alcohol IPA = carburrettor alcohol = all the same- and cotton buds.
Wipe wet and clean, then wipe dry.
