Hello,
I read that each model of Beogram 4002 has different belt dimensions. Is this true?
If so can someone hook me up with what the dimensions are supposed to be for the 5513 that would be sweet. If someone else could verify, that would also be appreciated.
Ok thank you everyone... so far I've taken a dumpy 4002 and fixed up the tonearm assembly completely dissected and rebuilt and it works LIKE BUTTER. I love the sound it makes when the tonearm is lowering - I might break it again by continuing to marvel at its beauty. Now on to getting the platter to spin (the motor is working) I need a belt.
PEACE!
The dimensions, friction and elasticity specs are not disclosed by B&O, but I can supply correct belts.Email or PM me.
