Beocom 2000 handset: how to open?
danielshen
Posts 78
danielshen Posted: Fri, Oct 12 2018 4:57 AM
Dear all,
Unfortunately my beocom 2000’ s handset is in the water. Now the voice from the handset is really really low. I want to open the handset to make some repair. Do you think it’s possible?
Thanks!
Daniel
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Oct 12 2018 8:33 AM
As far as I remember the only wat to disassemble is destructively!  You may be able to break the glued seam around the edge if you are very careful with a craft knife.  Then simply glue it back together.
Maurice
Posts 108
Maurice replied on Fri, Oct 12 2018 10:12 AM
The way to open this handset is "mechanically" if you are careful and have a bench vice wrap the handset in a microfibre cloth or similar then place the handset in vice speaker / ear set  facing up and along the split line . you can apply gentle pressure and you will hear cracking as you go. personally i would use a non metallic scraper to help prize/open the split line  so as to not damage the surface finish. use a TUBE of polystyrene model glue applied to the female portion of the handset  the ideal is get a controlled separation not a dig in and hope without the assistance of elastoplast plasters!
Maurice
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Oct 12 2018 12:22 PM
Why do you think the problem is in the handset?
Did you check the electronics in the main unit?
Page 1 of 1 (4 items) | RSS
