Power cable and speaker connection help
DinoD
Posts 38
DinoD Posted: Sat, Oct 13 2018 5:51 AM
Need a replacement power cable for Beolab 12-2
Does anyone know what the correct cable would be.
Also could anyone explain if there is a difference between the speaker set up.
1. Each speaker is connected individually to the TV
2. Speaker 1 is connected to speaker 2 and then 2 to the TV
is one better then the other?
Thank you for your help in advance.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi DinoD,
I stock the mains power cables for the speakers here with a choice of country fittings:-
https://soundsheavenly.com/search?controller=search&order=product.price.asc&s=mains
You can either connect each speaker directly to the TV, or daisy-chin one speaker from another if you prefer, there is no difference in terms of the sound.  Each speaker picks the correct audio channel via the switch setting on the back panel.
For earlier B&O TVs with 8 pin Powerlink sockets (eg. Beovision 7) please use these cables:-
https://soundsheavenly.com/bang-olufsen/31-325-rj45-to-powerlink-compatible-all-in-one-cable-convert-new-2013-ethernet-powerlink-to-traditional-8-pin-din-powerlink.html#/9-length-18m
For newer B&O TVs with RJ45 sockets (eg. Avant) please use these cables:-
https://soundsheavenly.com/powerlink-rj45-cat5-connection-models-from-2013/28-2264-rj45-powerlink-compatible-shielded-cable-for-beolab-speakers-2013-and-newer.html#/3-length-2m/18-colour-black
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (2 items) | RSS
