I have a problem with re-fiting the top plate on my Beogram 6000. One of the supporting pins is too high. I have not done anything to the deck except removed the top plate. What is the right procedure?
https://www.dropbox.com/s/7n4enm4nta142i6/beo6000.jpg?dl=0
https://www.dropbox.com/s/2bvbrtumd4pkkxx/beo6000pin.jpg?dl=0
Regards
Roger
The top plate on my 4002 has always been touchy to get in place. I mostly find I have to move the sliding front a little until it drops in. I would not try to change any of the pins. One of mine looked bent so I straightened it a little and the plate would not go on. It turned out it was bent at the factory to fit.
I finally got it in place. Some violence helped... Another problem arised, the sliding cover does not hold on one side. As it will go into storage, I will not bother now.
