Get 12V and preferable 5V from Beovision 7-32 MK3
Ravsted
Denmark
Posts 345
Ravsted Posted: Sat, Oct 27 2018 10:39 AM
I purchaced a BV7-32 MK3.
It will be fitted with a Cisco IPTV box connected via Scart (audio) and DVI.
The Cisco IPTV box will be controlled via Lintronic 5.1 which is receiving the B&O commands via Datalink (pin 8) from Scart.
Tested and working just fine.
Both boxes can be beautifully hidded behind the TV however I would like to avoid having power adaptors for those two boxes as well.
They are both powered with 12V DC. If I remember correctly total Amp is approx. 2A.
Is there any easy way to open the BV7 cabinet and get 12V from a connector inside the BV7. I think that would be a very elegant solution with less cable mess.
Preferrable I would also like to get 5V DC to power some USB slots... Just to be future proof.
Kind Regards
Ravsted
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Oct 27 2018 2:11 PM
Rather than go inside the BV7, I would be tempted to purchase a small/neat PSU and then provide a power supply from a Y-shaped power lead like this: https://www.ebay.co.uk/itm/Splitter-Lead-Cable-UK-3-Pin-Plug-to-2-x-IEC-C7-Y-Cable-Dual-Power-Cable-Black/163276077834?epid=24011372897&hash=item2604033b0a:g:jQ8AAOSwX8da9SrH
matador43
Posts 1,373
matador43 replied on Sat, Oct 27 2018 6:16 PM
I second Guy's answer. Thats what I did but with a triple one to power an Apple TV, an Airport Express hidden behind my recently acquired Beocenter 6.
That's just two wires out behind the stand: one power and and network, all tied in a sock.
I would not venture into taking power from inside the TV.
Page 1 of 1 (3 items) | RSS
