Gentlemen,
I am planning on extending our ML network by adding our Ouverture+BL2500 to the existing network. The preset network is driven by our living room set, which consists of a BV7+BS3200 which comprise the master unit in the system.
The main question remains, is there a way to force the Ouverture into audio slave mode? I would like to keep the Ouverture as a part of the system for the BL2500's don't look to great as stand alone speakers.
Best regards!
kammeri: ... is there a way to force the Ouverture into audio slave mode?
Press "RED DOT" & "LIST" simultanously >> Beo4 display canges to "ADD?"Press "LIST" till display shows "OPTION?"Press "GO"Press "LIST" till display shows "A.OPT"Press "5" if you own only audio products or "6" if there is a B&O Master-TV in the ML network
During entering "5" or "6" the red standby LED should "twinkle" = going off for a short time.
If this does not happen your BeoSound Overture is a very old model and you need the SW EPROM exchanged to get it Option 5/6 ready.
PS: visit the Beotech pages too ...
