Dear all,
I connect my beosound core with lab5 or lab3. I always use the Airplay to stream music from my music APP to beosound core. When I push Pause button in the APP, the music in beosound core is stopped; However, I notice the beolab speaker is always on (in green light).
Any way can we set the beosound core automatically standby time?
Thanks for input!
Daniel
Not that I know of - you’re just pausing the stream.
If you disconnect the Core from the AirPlay stream, it should go into standby after a while.
Other solution is to use the standby icon in the upper right corner of the (Core) product screen.
BeoNut since '75
