Beovox M150
stonecowboy
Posts 4
stonecowboy Posted: Fri, Nov 2 2018 12:22 PM
Hi All,
Looking for some advice on the best glue to use to reattach the coil on the mid range phase-link unit on my beovox M150, Not sure if the PVA used for refoam would be suitable was thinking more a 2 part epoxy or silicone. Any suggestions would be most welcome.
Gareth
stonecowboy
Posts 4
Would a gel super glue work?
stonecowboy
Posts 4
All sorted, thanks.
Page 1 of 1 (3 items) | RSS
