Anyone know how to adjust volume on the Beolink NL/ML with the B&O app? The old Beoremote app I used before doesn't work anymore
gbraen:Anyone know how to adjust volume on the Beolink NL/ML with the B&O app? The old Beoremote app I used before doesn't work anymore
BeoNut since '75
Yes, I use a Beolink Passive amplifier
gbraen:Yes, I use a Beolink Passive amplifier
elephant: gbraen: Yes, I use a Beolink Passive amplifier I am not sure we are talking about the same device ... . . . . Is this the sort of environment that you are enquiring about ?
I am curious there too.
Maybe he is refering to a BeoLink Passive (driving passive speakers) connected to the PL output of the Converter?
Or maybe the BeoLink Passive connected via ML to the Converter?
In the second case that would need an ir eye to be (volume) controlled....and can not be controlled via the app.
Yes, that's what I use.
Thanks - and it does not appear in the device list like shown by elephant?
@elephant
Is there maybe some setting in the converter for that - something that must be enabled?
elephant: gbraen: Yes, I use a Beolink Passive amplifier I am not sure we are talking about the same device ... Here is the new App (I am on the beta) In the middle of the 3 products is the silver BeoLink Converter ... it supports PowerLink but I do not have any speakers attached. The screen is showing all 3 units are linked in a group if I go to this view, and click on each rooms little speaker icon (I.e. not the X as that disconnects that unit from the group) I get the slider option to adjust an individual set of speakers within that room Is this the sort of environment that you are enquiring about ?
I have the same app. In the Beolink Group when I connect the NL/ML to my Beoplay A6 the volume control in the app doesn't appear on the NL/ML.. I have to use the volume control on the A6 to control the volume on the Beolink Passive(which is connected to passive speakers)
When I used the old Beoremote app I could use the volume control there for the NL/ML. But that app just crash on iOS 12.
Millemissen: Thanks - and it does not appear in the device list like shown by elephant? MM
It's appearing, but no volume control
Millemissen: @elephant Is there maybe some setting in the converter for that - something that must be enabled? MM
I asked on a facebook group, here is the answer:
Set it to "BeoLink Converter with Speakers"That will fix the issue
Great - problem solved then!
Millemissen: Great - problem solved then! MM
Don't know yet, haven't tried. Have no clue how to do it
"Veranda" is the Beolink, the volume control doesn't appear there. Why?
