Beomaster 5500
This post has 9 Replies | 2 Followers
KurtLA
Posts 7
KurtLA Posted: Sun, Nov 4 2018 3:25 PM
Hi
I have a beomaster 5500 with the big  master controller. When I turn down the sound using the whell on the controller to lowest level, 00 on the display, the sound is still quite high. I am not able to turn down the sound 100%. Can someone tell me if it possible to adjust the factory setting for the sound so 00 is totaly silence?
Thanks, Kurt
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Kurt,
Welcome to Beoworld!  Please can you tell us which model of speakers you have connected and which sockets they are connected to on the Beomaster?  This should help us to identify the cause of the issue.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
KurtLA
Posts 7
KurtLA replied on Fri, Nov 9 2018 1:26 PM
Hi Steve
It is beovox 3000 type 6716 and they are in sockets no. 1.
Thanks, Kurt
KurtLA
Posts 7
Hi Steve
Thanks, Kurt
KurtLA
Posts 7
Hi Steve
Thanks, Kurt
Posts 2,165
Hi Kurt,
Thanks for your reply - this could be a remote control issue - are you able to try a different remote control please?
Steve.
KurtLA
Posts 7
KurtLA replied on Mon, Nov 12 2018 9:18 AM
Hi Steve. I have two master controller and two beolink 1000. No one can turn it down. All can turn the volume up. But when it is turned fully down and the beomaster show 00 on the display the volume is like when you listning in a "normal" level.
Thanks, Kurt.
KurtLA
Posts 7
Thanks, Kurt.
Posts 2,165
Hi Kurt,
Thanks for your reply.  This sounds like a fault on the Beomaster - it could be worth getting this checked out by a local repairer.
Steve.
KurtLA
Posts 7
KurtLA replied on Wed, Nov 14 2018 9:18 PM
Hi Steve. Thanks for your try. I will go to a local support. Thanks, Kurt
Page 1 of 1 (10 items) | RSS
