Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hiort:Are you on the Beta track or have AP2 been included in the commercial release?
Not on my Essence (2nd gen) yet.
One question @Dyssegård
Are you still able to redistribute an airplayed source to (an)other NL device(s) - like we have been before?
Millemissen:Not on my Essence (2nd gen) yet. One question @Dyssegård Are you still able to redistribute an airplayed source to (an)other NL device(s) - like we have been before? MM There is a tv - and there is a BV.
The Essence is supposed to be in the second run (according to another thread, that I can’t find).
Funny - BeoTool and the app shows that there is an update for my M3. But it won’t let me update manually.
I guess I’ll have to wait and see, what will happen over night.
Millemissen:The Essence is supposed to be in the second run (according to another thread, that I can’t find). Funny - BeoTool and the app shows that there is an update for my M3. But it won’t let me update manually. I guess I’ll have to wait and see, what will happen over night. MM There is a tv - and there is a BV.
That is what I did - you can not update from BeoTool!
Still the option of updating there does nothing.
Actually I am more interested in the AirPlay to NL distribution feature - if that is kept untouched with the new update?
Since I have no ‘only-AirPlay-devices’, AirPlay 2 won’t give me much improvement.
Millemissen:That is what I did - you can not update from BeoTool! Still the option of updating there does nothing. Actually I am more interested in the AirPlay to NL distribution feature - if that is kept untouched with the new update? Since I have no ‘only-AirPlay-devices’, AirPlay 2 won’t give me much improvement. MM There is a tv - and there is a BV.
Thanks - found it!
That must be a bug in the sw.
Also when I disabled ‘automatic sw update’ for the Essence in the ‘configuration part, it did not show up there....I had to change the setting there too.
As for AirPlay 2 and AirPlay->NL distribution, I’d better make some tests with the M3, before I’ll allow automatic updating of my Essence.....hmmmm.
Though I don’t use that much, I have always thought that the NL distribution is handy - it happens within the app.
To go outside, into the AirPlay control panel of the iDevice, isn’t smart.
That said - there will be setups, where this is good —— when you have non-B&O AirPlay devices around the house mixed with B&O devices.
Please do tell about any observation on this matter.
Millemissen:Thanks - found it! That must be a bug in the sw. Also when I disabled ‘automatic sw update’ for the Essence in the ‘configuration part, it did not show up there....I had to change the setting there too. As for AirPlay 2 and AirPlay->NL distribution, I’d better make some tests with the M3, before I’ll allow automatic updating of my Essence.....hmmmm. Though I don’t use that much, I have always thought that the NL distribution is handy - it happens within the app. To go outside, into the AirPlay control panel of the iDevice, isn’t smart. That said - there will be setups, where this is good —— when you have non-B&O AirPlay devices around the house mixed with B&O devices. Please do tell about any observation on this matter. MM There is a tv - and there is a BV.
Thanks for taking the time!
