Beolab 50 won't install
Peter Dorr
Soest
Posts 22
Peter Dorr Posted: Sun, Nov 11 2018 3:27 PM
I have a pair of Beolab 50's connected through RCA to my Marantz SR8012 amplifier.
It worked well untill I wanted to do a mic calibration. The speakers stopped responding after I put the mic in.
Ok, so I pulled out the mic but now I cannot get the speakers to work anymore. They do not play music and the app cannot find them either. Not even after 2 factory resets.
Since I cannot find a proper setup manual I am wondering if you could help?
This is what I have as a setup:
- Connected the Master to the slave with a network cable. Powerlink in master, network on slave
- RCA in on the Master speaker as Front Left and Front right speaker
- No cabled network connection to my home network, I use WiFi
Please help me with a proper Factory Reset and config setup and sequence.
Many thanks, much appreciated
Peter
Millemissen
Flensborg, Denmark
Posts 14,680
Peter Dorr:
Is this the guide, you are looking for - seems to be quite ‘proper’.
https://www.bang-olufsen.com/~/mediaV3/home/collection/collection-speakers/BeoLab-50/bang-olufsen-beolab50-whitepaper-v5.pdf
I am not quite sure, what you mean with that cabling....
....but the guide should tell you, what is right (or wrong) there.
Peter Dorr
Soest
Posts 22
Pffff it works again.
I have connected the two speakers with a network cable not using the Powerlink connector, just the network connector.
I have done a factory reset 3 times and finally it worked again.
No idea what solved it but it took me the best part of an afternoon to solve everything
Happy that it works again.
Page 1 of 1 (3 items) | RSS
