How can you identify a Beolink Converter with no label?
toresbe
Oslo, Norway
Posts 2
toresbe Posted: Sun, Nov 11 2018 4:22 PM
Hey folks,
I'm setting up a Masterlink connection to my Beosystem 7000. To this end, I'm using a Beolink Converter I got together with some other kit in an online classified ad.  I connect the audio aux link between the Beomaster 7000, and Masterlink from the Converter to a Beolink Passive.
However, this isn't working. Now, if I've understood things correctly, I will need a Beolink Converter that isn't a type 1614 allow my Beosystem 7000 to function as an audio master. But my Converter was attached in its previous home with double-sided tape that has torn off the label.
Does the forum know if there are any tell-tale signs of either a 1614 or a 1611 if I open and peek inside?
Leif
Middle Jutland in DK
Posts 130
Leif replied on Thu, Dec 27 2018 1:21 PM
Open it, remove the thin metal cover and look at the Eprom label
Page 1 of 1 (2 items) | RSS
