Beogram 1202 Bearings
This post has 6 Replies | 0 Followers
Keith
Shrewsbury
Posts 138
Keith Posted: Mon, Nov 12 2018 4:08 PM
does any one have the equipment to vacuum re oil the bearings for a Beogram 1202?
Saint Beogrowler
Saint Paul
Posts 780
I just use a home jar vacuum sealer and it works.
Here is how I did my last BG 3000 (like the 1202) repair but I don't have pictures of the sealing process.
https://archivedforum2.beoworld.org/forums/t/30994.aspx
Keith
Shrewsbury
Posts 138
Keith replied on Mon, Nov 12 2018 4:59 PM
Do you have a photo of the unit you us and where you acquired it.
Saint Beogrowler
Saint Paul
Posts 780
FoodSaver T03-0023-01 Wide-Mouth Jar Sealer https://www.amazon.com/dp/B00005TN7H/ref=cm_sw_r_cp_api_tvB6BbDNDGCFH
https://www.foodsaver.com/vacuum-sealers/handheld-vacuum-sealers/the-foodsaver-freshsaver-handheld-vacuum-sealing-system/FSFRSH0051-P00.html#start=2
If I were to purchase again I might look for a different option for the handheld sealer part. This one is a little underpowered with poor batter life for daily jar sealing use but I’ve done at least 5 sets of bearing with good results with this combo.
Pascal
Belgium
Posts 1
Pascal replied on Mon, Nov 12 2018 6:27 PM
I use a syringe. i put the bearings in the syringe together with some very thin oil, put my finger on the hole and pull. The baering will start to bubble. Easy and works very well.
Keith
Shrewsbury
Posts 138
Keith replied on Mon, Nov 12 2018 6:45 PM
Many thanks guys.
will try the cheap option first, then go the whole hog if it doesn’t work.
Saint Beogrowler
Saint Paul
Posts 780
Pascal:
That’s a cool idea!
Page 1 of 1 (7 items) | RSS
