Good morning all,
I am new to the forum and wondered if anyone had a Beocenter 3300 to help me reassemble one I bought in a few bits?
I am unsure how the spring mechanism goes back together for the “Programming” panel? I have the spring and the hook but can’t seem to find a way of putting them together to make the hinge open automatically?
Any help especially images of a completed mechanism would be hugely helpful!
Many thanks,
Dan (Currently a very confused individual)
The little spring goes from the hook at the end of the damper arm to a smallhole in the black metal plate just above it.Its function is to hold up the damper arm.
Hi Martin,
just wanted to say thank you for the advice on this... managed to get it working properly. Sorry for the delayed reply.
Cheers
Dan
