Beocord 7000 erasing tape problem
DStefan
Posts 25
DStefan Posted: Thu, Nov 15 2018 2:41 PM
Everything works fine on this machine, except that it doesn’t erase tapes like it should. You stil hear most of the previous recording. Cleaned and demagnitised the heads but that had no effect. Anybody with A possible solution. I also checked the wiring, seems ok. Thanks!
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Nov 15 2018 2:45 PM
Check the erase head for continuity and the function of the erase oscillator.
DStefan
Posts 25
DStefan replied on Thu, Nov 15 2018 7:48 PM
Thanks,  but I guess this is beyond my skills....or is there an easy way to check this?
Dillen
Posts 13,191
Dillen replied on Thu, Nov 15 2018 8:49 PM
A Ohmmeter (multimeter) across the erase head (out of circuit) and a scope to the oscillator when recording.
Careful, there are high voltages here and there.
A job for a tech guy, really, but shouldn't be too difficult or expensive.
DStefan
Posts 25
DStefan replied on Thu, Nov 15 2018 10:16 PM
Thanks!
Page 1 of 1 (5 items) | RSS
