Beomaster 6000 volume preset not working
thch
Posts 20
Silver Member
thch Posted: Thu, Nov 22 2018 10:54 PM
Hi.
There is propably a simple fix, but I haven't been able to find any help in this forum.
Problem: Beomaster 6000 (type 225x), volume v and ^ works. Preset volume using slider goes all the way up when not in zero. (either 12V or -12V across motor unless at zero). Preset value 0 works, value 10, 20, 30, 40, 50, 60 goes all the way to 60 and motor keeps turning (12V on motor).
I have tried the following: All transistors on pcb 6 is OK. Recapped pcb6, resoldered all connectors. Recapped pcb 3, tested volume pot (3R4) 100K ok. Changed pots 6R25, 6R24 and 6R32.
Supply voltage to pcb6 is ok. IC3 is ok.
Preset voltages (measured on cathode 6D8) are all ok (1V to 15V)
Have not changed 6IC5.
When trying to calibrate volume control:
1. volume step 0: Not possible since volume goes all the way up when pressing preset 30. In position 0 voltage on motor is 0V
2. preset volume 0: OK, when preset pot low,  voltage across motor (5TP20 and 5TP21) is 0V
3. v ^¨ volume speed: OK, 6,5V across motor when buttons are pressed
What am I missing?
Regards Thomas.
thch
Posts 20
Silver Member
thch replied on Fri, Nov 23 2018 8:46 PM
Anyone ?
thch
Posts 20
Silver Member
Anyone ?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Nov 24 2018 7:35 AM
Check for cracked solder joints at the volume control board and also at
the connectors along the lower edge (in serviceposition) of the CPU board.
thch
Posts 20
Silver Member
thch replied on Mon, Nov 26 2018 1:23 PM
I found a "CPU donorboard" from another dead BM6000 and that worked, thanks for guiding me in the right direction.
Is it easy to kill the CPU in these machines? The CPU donorboard wasn't working until I changed the CPU (the error was just showing the small 3 dots in the frequency display). I thought that stuff was pretty reliable....
Dillen
Posts 13,191
Dillen replied on Mon, Nov 26 2018 1:51 PM
It's CMOS - it's always sensitive to static electric discharging.
ALWAYS work in an ESD-safe workplace with correct tools, wrist-strap etc.  - particularly when working with CMOS.
sonavor
Texas, United States
Posts 3,732
sonavor replied on Mon, Nov 26 2018 1:54 PM
Changing the board doesn't mean the problem was with the microcomputer IC itself. It just means there is likely a connection problem with that board. Don't discard that old board and microcomputer IC in the trash. People suspect the microcomputer all the time when something doesn't work and it is rarely the case. It is almost always a missing or faulty signal to the microcomputer IC.
-sonavor
thch
Posts 20
Silver Member
thch replied on Tue, Nov 27 2018 11:35 AM
Well, I have tried to place the uP in a working processorboard and only output is the 3 dots on the freq. display. So I guess the uP is dead.
Page 1 of 1 (8 items) | RSS
