Beogram 5500 does not spin, block or stuck
Ignacio
Barcelona
Posts 39
Ignacio Posted: Sun, Nov 25 2018 10:39 AM
Hello,
I have recently bought a BG 5500 that refuses to spin, the platter is stuck or blocked.
To open the TT I had even to disconnect the carriage wire to move the tone arm and detector to the center position to raise the system.
Gears are block, no spins, I guess something (gear) most be out of postion but I can't see anything in the wrong position.
¿Did someone experiment the same problema? ¿Any recommendation to fix it?
¿Is it possible to find a clear description of how to dismantle the pinions and gears?
Any help would be more tan welcome.
Thanks you so much
leosgonewild
Helsinki, Finland
Posts 2,373
Did you loosen the transport screws?
Ignacio
Barcelona
Posts 39
Ignacio replied on Sun, Nov 25 2018 5:54 PM
Yes I did.
I have encouraged myself to dissamblenging the upper pinion, the ones which move the arm, I'm on this.
I think that the gear was out of place.I will come back with my findings and hopefully sa soliution.
Ignacio
Barcelona
Posts 39
Ignacio replied on Thu, Nov 29 2018 7:59 PM
Hi Leos,
Solved!
The big gear was out of place.
Now seems that will work.
Regards
Ignacio
Barcelona
Posts 39
Hi Leos,
Solved!
Regards
leosgonewild
Helsinki, Finland
Posts 2,373
Great news! Enjoy the music Big Smile
Page 1 of 1 (6 items) | RSS
