I have a Beovision Avant 28 which I use with my Sky box connected by scart cable, and my Beo4 remote. Sky box is the 'SAT' input on TV and remote. It has worked perfectly for years, but has just developed a problem: When TV turned on and switched to SAT source, after a few minutes the TV automatically switches to VTAPE then to TV source. I reselect SAT (on remote or TV) but after a few seconds it switches back to VTAPE then TV, and sometimes flips between these.
I have ruled out a problem with the Beo4 remote (took batteries out, problem still occurs with TV). I have tried using the other scart socket and 'DVD' source for the Sky box, problem still occurs.
A possibly related issue occasionally happens - TV in standby mode but can't be switched on using buttons on top or remote, until it is powered off at the wall then powered on again, then switches on fine.
Grateful for any help or advice - otherwise have large useless lump of glass and metal in corner of room! Thanks
