Pairing Beoremote One with Beosound Essence MK2
This post has 31 Replies | 2 Followers
ibg001
Posts 80
ibg001 Posted: Tue, Nov 27 2018 6:05 PM
Hi
Can a Beoremote One BT be paired with Beosound Essence MK2? I have tried without success.
And yes I know I can use it without bluetooth with an IR eye which I do at the moment.
christiank
Posts 64
I just tried it, and it works fine. Make sure your Essence MK2 is updated (new sw today).
Millemissen
Flensborg, Denmark
Posts 14,680
With the latest software - of today - all ‘connected devices’ can be paired with a BROne/bt.
jans
Belgium
Posts 394
jans replied on Tue, Nov 27 2018 8:07 PM
I was able to successfully pair the Beoremote One, but I couldn’t pair the remote with my Essence. The Essence is currently controlled through an IR eye. Maybe that is why I couldn’t pair the Essence?
christiank
Posts 64
It can do both simultaneous. Try a reboot.
Jon
Hampshire, United Kingdom
Posts 241
Jon replied on Tue, Nov 27 2018 8:42 PM
Just to clarify, does this include the A6?
jans
Belgium
Posts 394
jans replied on Tue, Nov 27 2018 8:56 PM
Jon:
Yes. I could pair my remote with an A6; but am still struggling on pairing with an Essence
beojeff
USA
Posts 2,012
beojeff replied on Wed, Nov 28 2018 1:11 PM
I was able to pair with my BS1 and A6 effortlessly. I see that it keeps multiple added products in its list of products. However, it only remains paired with the last product paired. It can't retain the pairing with multiple products.
You CAN however keep multiple remotes paired with a device. For example, keep a BeoRemote One and an Essence remote both paired to an A6.
jans
Belgium
Posts 394
jans replied on Wed, Nov 28 2018 6:48 PM
Problem solved! The batteries of the remote were almost dead, so opening the remote for Bluetooth pairing did not send any BT signal. Changing to new batteries solved everything! Big Smile
I am very happy that I can now use a single B&O remote for all my devices! I have been waiting for this for a long time! These are the ‘little things’ that me happy as a B&O customer.
One strange thing I noticed. The remote nicely shows all sources available, except for Spotify. Is this a bug, or is there a good reason why it is not shown as a source on the remote?
Furthermore, all sources of the Beovision are shown, even the sources which are not in use. I would have preferred to only see the ‘active’ sources of my V1
ibg001
Posts 80
ibg001 replied on Wed, Nov 28 2018 8:10 PM
After the software on the Essence was updated the paring of the Beoremote One worked fine!
This is great. Now I can see the TuneIn stations on the Beoremote One.
But this new setup also raise some questions?
  1. Is the a limit to how many TuneIn stations from the favorite list that can be shown on the Beoremote One? Not all of mine is shown.
  2. How do I  remove source for the source list? I want for instance to remove QPlay form the source on the Beoremote One. I have configured the local source list for the Essence in the Bang&Olufsen app.
  3. Do Essence not support to configure the 4 configurable my buttons on the Beoremote One? I can find it in app, but it is empty cannot be edited.
Millemissen
Flensborg, Denmark
Posts 14,680
No support for the MyButtons yet!
Will be nice to have that too, imo.
Millemissen
Flensborg, Denmark
Posts 14,680
jans:
Spotify (Connect) is not a built-in source and can not be shown or activated.
In the app you also need to go ‘outside’  to activate music playback from Spotify = use the native Spotify app.
beojeff
USA
Posts 2,012
beojeff replied on Wed, Nov 28 2018 10:00 PM
I'm now finding that the BeoRemote One DOES retain the pairing with multiple devices. Maybe it just takes it a moment to establish the connection.
However, I'm finding that the LIGHT/CONTROL commands are not working correctly to forward commands to the BLGW. Monitoring events on the BLGW shows no activity.
Razlaw
Posts 4,345
Razlaw replied on Thu, Nov 29 2018 12:46 AM
This is very interesting! I have a BeoRemote One ordered to use with my Core. Will be curious to see if I like it well enough to get one for use with my Essence as well.
beojeff
USA
Posts 2,012
beojeff replied on Thu, Nov 29 2018 4:20 AM
I feel like B&O gave us an early Christmas gift. The remote is now so much more useful than it was before. The 2-way list of TuneIn stations is just extremely impressive. I feel like I'll use TuneIn more now because of it. I also now want to replace all of my Beo4 remotes with BeoRemote One remotes.
Razlaw
Posts 4,345
Razlaw replied on Thu, Nov 29 2018 4:30 AM
Does it provide any information with Deezer?
ibg001
Posts 80
ibg001 replied on Thu, Nov 29 2018 6:34 AM
Regarding MyButtons. It does actually works. Store something in one of the buttons like a TuneIn station. It must be done on the remote then you will it in the app afterwards.
ibg001
Posts 80
ibg001 replied on Thu, Nov 29 2018 6:37 AM
Not all favourite stations are shown on the remote. There must be a maximum number of stations.
Millemissen
Flensborg, Denmark
Posts 14,680
ibg001:
Thanks!
That is new to me - my information was that this was left for later.
With which device did you try this out?
ibg001
Posts 80
ibg001 replied on Thu, Nov 29 2018 12:31 PM
I tried with Beosound Essence mk2.
jans
Belgium
Posts 394
jans replied on Thu, Nov 29 2018 12:32 PM
ibg001:
And A6
1990
Posts 521
1990 replied on Mon, Dec 3 2018 11:25 AM
Bought a new Beoremote yesterday and here are some things I discovered while testing:
Probably bugs:
* On BeoPlay M3 + M5 the remote lists ALL sources from connected devices instead of the Local Source List that is used in both the App and for local souce selection
* The Music-button on a Beo4-VIDEO product (in my case the V1) directly starts the Radio (so without pressing 'GO'). I don't even want to use the Radio button, but it can't be deleted. I just want Join, but cannot Join current Music-playback because the Radio-button has already switched my M5 to Radio.
Features/good to know:
* You can add TuneIn-stations to the MyButtons
* The MyButtons are Product-specific
* Light and Control-buttons are programmed as standard on BeoPlay M3 and M5. So I guess you can use the BeoRemote for home control even if you have programmed it with just NL sound products.
Wishlist:
* Better Deezer-control e.g. programming a Playlist/Artist on a MyButton or in a Favorites list so you can have 10 "shortcuts" for selection from the remote (maybe this can be achieved with the BeoIntelligence?)
* Programming system-wide MyButtons (e.g. "Kitchen Speaker Join")
jimcaj
Denmark
Posts 126
jimcaj replied on Wed, Dec 5 2018 5:24 PM
beojeff:
Ditto. Because of this, I just bought another M5 and my first Beosound Core. Planning on getting a BR One.
/ mike
Dyssegaard
Copenhagen, Denmark
Posts 263
Millemissen:
I have paired my new BeoRemote One BT with my Beoplay M5, and it is possible to save Spotify in a MyBotton.
Just press and hold the desired MyBotton for a few seconds when listening to Spotify, and you will be able to activate Spotify Connect again where you left it using that MyBotton. The app will show you the functionality of each of the 4 MyBottons:
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
chucky
Posts 331
chucky replied on Sun, Dec 23 2018 8:43 PM
For me it is not working on a core in the bathroom. I have a core a BLGW for lights. I want lights on the my favorite button, I cannot get it done after pairing....
If I use IR Mode no problem?
Millemissen
Flensborg, Denmark
Posts 14,680
Dyssegaard:
And what happens, when you in the meantime have activated e.g TuneIn on the M5 - or when you have used Spotify (Connect) on the iDevice with headphones or with another device?
Dyssegaard
Copenhagen, Denmark
Posts 263
Millemissen:
I can use Spotify on my BV11/Core integrated setup, play TuneIn on the M5, and after that the MyButton still activates Spotify on the M5.
In fact I can also save Spotify in a MyButton on the BV11/Core integrated setup (using ir control on the TV) and it works after using other sources on the TV. It also works after all my devices have been turned off.
Millemissen
Flensborg, Denmark
Posts 14,680
@Dyssegaard
Thanks for clarification (that is really better, than I had expected).
And it is really a big plus for having Spotify Connect on the NL devices.
I can’t understand why they have taken this out of the M3, the BS1/2 GA versions, the Edge and the coming A9/MK3 😕
ibg001
Posts 80
ibg001 replied on Sat, Jan 19 2019 7:53 AM
Is there a limit on Beoremote One on how many favorites from TuneIn that will be shown? On my Beoremote One paired with Beosound Essence I cannot browser through the full list of favourite stations.
Dyssegaard
Copenhagen, Denmark
Posts 263
ibg001:
I have paired my Beoplay M5 with my Beoremote One BT, and my 16 favorites (placed in the “General” folder in TuneIn) are all visible on the Beoremote.
andybandy
Posts 164
andybandy replied on Sat, Jan 19 2019 9:10 AM
Hi
It seems it product dependent. BeoSound Core, cannot store mybotton at all, but work with the beoremote one Bt. But BS 1 and M5 work great. Both with Radio and Spotify, that have been tested, i expect Deezer work. (but not tested)
So hopefully it will coming a update to core start of februar. I have send them a request for it.
If more people send in request to them, hire priority they will get.
andybandy
Posts 164
andybandy replied on Sat, Jan 19 2019 9:52 AM
Millemissen:
@Dyssegaard
I think they know, more then we know. Maybe Spotify connect will stop working in the future, when Google cast and Airplay 2 take over how we use the music in all product over the world. Then Spotify see no reason to keep up with Spotify connect.
I know this is alot of feelings in this topic, but the multiroom world, goes in this direction i believe. :)
And if people want to discuess on that, your welcome:)
But I also miss the Spotify connect sometimes, but airplay 2 work for me:)
Page 1 of 1 (32 items) | RSS
